so It is a plan to allow one to multi-select, or heck I would be happy with an excel import, or finally, the thing I find often is the series is s101 s102 instead of s01 s02… Can we at least add the ability to strip the leading character IF there is not a match? At least that would work for the first 99 if anything had that many!
You could try this: https://github.com/Webreaper/SonarrAutoImport - use the ‘Transforms’ function to auto-rename: Penn & Teller - Bullshit!\7\7|Penn & Teller - Bullshit!\7\
would do it.
Select only the episodes you want to set the episode number for
Press Select Episodes
Select the episodes
A couple limitations:
The order matters, episodes will be set on the selected files based on the displayed order
The number of selected episodes must be a multiple of the selected number of files (If you select 2 files, you need to select 2, 4, 6, 8, etc number of episodes and they will be set on the files accordingly, select 4 would set 1 & 2 on the first and 3 & 4 on the second)
