**Sonarr version 2.0.0.5301
OS: Win7 64bit
This has been an issue for about a month (last update?) and has worked flawlessly prior to that. It’s giving a weird message in the log whenever I try import a file.
Couldn’t import episode E:\sonarr\Video.mkv: E:\sonarr\Video.mkv is not a child of E:
Thinking for some reason Sonarr no longer sees the sonarr folder assigned to import, I created a new import folder called Temp and received the same message.
EXCEPTION:
NzbDrone.Common.Disk.NotParentException: E:\sonarr\Video.mkv is not a child of E:
at NzbDrone.Common.Extensions.PathExtensions.GetRelativePath(String parentPath, String childPath) in M:\BuildAgent\work\5d7581516c0ee5b3\src\NzbDrone.Common\Extensions\PathExtensions.cs:line 62
at NzbDrone.Core.MediaFiles.EpisodeImport.ImportApprovedEpisodes.GetOriginalFilePath(DownloadClientItem downloadClientItem, LocalEpisode localEpisode) in M:\BuildAgent\work\5d7581516c0ee5b3\src\NzbDrone.Core\MediaFiles\EpisodeImport\ImportApprovedEpisodes.cs:line 175
at NzbDrone.Core.MediaFiles.EpisodeImport.ImportApprovedEpisodes.Import(List`1 decisions, Boolean newDownload, DownloadClientItem downloadClientItem, ImportMode importMode) in M:\BuildAgent\work\5d7581516c0ee5b3\src\NzbDrone.Core\MediaFiles\EpisodeImport\ImportApprovedEpisodes.cs:line 105
