Maintain Collection at Highest Quality
Mono version (if Sonarr is not running on Windows): 4.0.4 ((detached/d481017 Mon Sep 28 17:32:19 EDT 2015)
OS: OSX
I’m just wondering if it is possible to configure Sonarr to maintain my collection of shows at the highest available quality but to still prioritize downloading every episode regardless of quality.
So if the only version of a show available is an SD rip it goes and gets that SD rip but then if 6 months later someone releases a 1080p version or even a 4k version then it automatically downloads the higher quality episode and deletes the old one.
Thanks,
Edit profile, enable all qualities that you’d be okay with downloading. Then set the cutoff to the highest quality of those you chose. Done.
Thanks!
And Sonarr will automatically delete the lower quality versions? I’ve had the ocassional instance where I’ll have duplicates of an episode of various qualities.
Yep, it will :slight_smile:
