Request Failed: The underlying connection was closed: A connection that was expected to be kept alive was closed by the server.
Exception
System.Net.WebException: The underlying connection was closed: A connection that was expected to be kept alive was closed by the server. —> System.IO.IOException: Unable to read data from the transport connection: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. —> System.Net.Sockets.SocketException: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond
at System.Net.Sockets.Socket.Receive(Byte[] buffer, Int32 offset, Int32 size, SocketFlags socketFlags)
at System.Net.Sockets.NetworkStream.Read(Byte[] buffer, Int32 offset, Int32 size)
at System.Net.FixedSizeReader.ReadPacket(Byte[] buffer, Int32 offset, Int32 count)
at System.Net.Security._SslStream.StartFrameHeader(Byte[] buffer, Int32 offset, Int32 count, AsyncProtocolRequest asyncRequest)
at System.Net.Security._SslStream.StartReading(Byte[] buffer, Int32 offset, Int32 count, AsyncProtocolRequest asyncRequest)
at System.Net.Security._SslStream.ProcessRead(Byte[] buffer, Int32 offset, Int32 count, AsyncProtocolRequest asyncRequest)
at System.Net.TlsStream.Read(Byte[] buffer, Int32 offset, Int32 size)
at System.Net.PooledStream.Read(Byte[] buffer, Int32 offset, Int32 size)
at System.Net.Connection.SyncRead(HttpWebRequest request, Boolean userRetrievedStream, Boolean probeRead)
at NzbDrone.Core.Rest.RestSharpExtensions.ValidateResponse(IRestResponse response, IRestClient restClient) in m:\BuildAgent\work\6c3239faf2b92630\src\NzbDrone.Core\Rest\RestSharpExtensions.cs:line 33
at NzbDrone.Core.Rest.RestSharpExtensions.Read[T](IRestResponse restResponse, IRestClient restClient) in m:\BuildAgent\work\6c3239faf2b92630\src\NzbDrone.Core\Rest\RestSharpExtensions.cs:line 60
at NzbDrone.Core.Rest.RestSharpExtensions.ExecuteAndValidate[T](IRestClient client, IRestRequest request) in m:\BuildAgent\work\6c3239faf2b92630\src\NzbDrone.Core\Rest\RestSharpExtensions.cs:line 72
at NzbDrone.Core.Download.Clients.Deluge.DelugeProxy.ProcessRequest[TResult](IRestClient client, String action, Object[] arguments) in m:\BuildAgent\work\6c3239faf2b92630\src\NzbDrone.Core\Download\Clients\Deluge\DelugeProxy.cs:line 226
at NzbDrone.Core.Download.Clients.Deluge.DelugeProxy.ProcessRequest[TResult](DelugeSettings settings, String action, Object[] arguments) in m:\BuildAgent\work\6c3239faf2b92630\src\NzbDrone.Core\Download\Clients\Deluge\DelugeProxy.cs:line 181
at NzbDrone.Core.Download.Clients.Deluge.DelugeProxy.SetLabel(String hash, String label, DelugeSettings settings) in m:\BuildAgent\work\6c3239faf2b92630\src\NzbDrone.Core\Download\Clients\Deluge\DelugeProxy.cs:line 157
at NzbDrone.Core.Download.Clients.Deluge.Deluge.AddFromTorrentFile(RemoteEpisode remoteEpisode, String hash, String filename, Byte[] fileContent) in m:\BuildAgent\work\6c3239faf2b92630\src\NzbDrone.Core\Download\Clients\Deluge\Deluge.cs:line 62
at NzbDrone.Core.Download.TorrentClientBase1.DownloadFromWebUrl(RemoteEpisode remoteEpisode, String torrentUrl) in m:\BuildAgent\work\6c3239faf2b92630\src\NzbDrone.Core\Download\TorrentClientBase.cs:line 146 at NzbDrone.Core.Download.TorrentClientBase1.Download(RemoteEpisode remoteEpisode) in m:\BuildAgent\work\6c3239faf2b92630\src\NzbDrone.Core\Download\TorrentClientBase.cs:line 90
at NzbDrone.Core.Download.DownloadService.DownloadReport(RemoteEpisode remoteEpisode) in m:\BuildAgent\work\6c3239faf2b92630\src\NzbDrone.Core\Download\DownloadService.cs:line 66
at NzbDrone.Api.Indexers.ReleaseModule.DownloadRelease(ReleaseResource release) in m:\BuildAgent\work\6c3239faf2b92630\src\NzbDrone.Api\Indexers\ReleaseModule.cs:line 67
at NzbDrone.Api.Indexers.ReleaseModule.<.ctor>b__0(Object x) in m:\BuildAgent\work\6c3239faf2b92630\src\NzbDrone.Api\Indexers\ReleaseModule.cs:line 46
at CallSite.Target(Closure , CallSite , Func`2 , Object )
at Nancy.Routing.Route.<>c__DisplayClass4.b__3(Object parameters, CancellationToken context)
Close
