When Click on the various filters for the log, the only one that works is the one for errors.
The All Filter shows Info, Warnings and Errors
The Info Filter shows Info, Warnings and Errors
The Warn Filter shows Warnings and Errors
The Error Filter shows Errors only
I’m pretty sure that’s how most log filters work. You’re essentially choosing to whittle down the entries based on significance, not necessarily to isolate one particular type.
No offense but that makes no sense… Why have 2 filters show you the exact same thing?
It’s like if i go to series and i say show me All Series, now show me only the monitored ones and it still shows me all series even if half of them are unmonitored
Yeah, the “All” filter is unnecessary and is probably why you expected the behavior you expected.
Your example is flawed. Monitored and Unmonitored are mutually exclusive.
The Info filter shows all Info entries + anything “worse” (Warnings and Errors).
The Warning filter shows all Warnings + anything “worse” (Errors)
The Error filter shows only the “worsest” entries.
Either the buttons should isolate each type of entry like you are expecting, or the “All” button should be eliminated and they should work as they do now, possibly also automatically depressing the buttons to the right of the one selected to give a better indication of what’s being displayed.
