I pressed logout, to log out and then log back in by login and password, but the access to the sonarr panel did not return. Does anyone have any suggestions for entering web-access again. By checking the status by command, SONARR is normally active.
Login is correct, but does not open the web access section, by command sonarr is active and even backing up.
By using the command belowh, I can even make it work, but when closing the command line, the web access stops working again. Until I pressed the logout of the sonarr, before everything worked perfectly.
I don’t understand what you mean, when you try to login what happens? Does the login page show again? Does it display an error? Does the login page not show at all?
The only thing logout does is log the browser out, it doesn’t change how Sonarr is running.
If you running Sonarr manually is under a different user than normally then my guess is the username/password is not set to what you think it is and you should follow the steps on the Wiki to reset it.
Being able to solve it, I installed “sonarr” again, and before I used the update and upgrade commands by command line. It returned to work, just not being able to import any backup of the configuration that was before, I will have to configure it from the beginning.
