Lock Episodes or Series against Deletion
Normally when I watch a series I delete the episodes as I finish them. However, occasionally I would like to retain a particular episode (e.g. a particular episode in a documentary programme series). However, I have occasionally accidentally deleted episodes that I wished to keep without realising.
REQUIREMENTS
As the owner of a library
I would like to tag an episode or series to not allow deletion
So that I don’t accidentally delete an item which is important.and I want to keep
I would like to be unable to delete an episode if the episode or series is flagged as “keep” when deleting an episode, series or programme
So that important episodes are not easily removed.
I would like to be able to untag an episode or series by explicitly removing the tag and re-attempting to delete it.
So that I can subsequently delete the item with some effort required.
NOTE: This functionality should also impact Plex’s ability to delete tagged episodes, but I’m not sure how easy that would be to implement… It may be worth communicating with Plex developers to see if a tag can be applied that prevents Plex from deleting an episode as well.
