Sonarr version 4.0.1.929
Linux Mint 21.3
Hello, trying to get Sonarr configured on Linux Mint. Everything installs correctly, I entered the username and group on install, but when I try to import existing series, it doesn’t see inside my mounted USB drive. Note that I have very basic Linux knowledge. I’ve been able to setup the permissions correctly for Plex and Sabnzbd+ but can’t figure out what I’m doing wrong with Sonarr.
I’m trying to run it as my main user which is the same one used on my mounted USB drive:
m***@PLEX:/mnt$ ls -l
total 1024
drwxr-xr-x 11 m*** m*** 1048576 Feb 23 09:13 shared_storage
Checked that the same user is listed in the service to make sure i didn’t make an error on install.
systemctl cat sonarr
# /etc/systemd/system/sonarr.service
[Unit]
Description=Sonarr Daemon
After=syslog.target network.target
[Service]
User=m***
Group=m***
UMask=0002
Type=simple
ExecStart=/opt/Sonarr/Sonarr -nobrowser -data=/var/lib/sonarr/
TimeoutStopSec=20
KillMode=process
Restart=on-failure
[Install]
WantedBy=multi-user.target
Any help would be greatly appreciated.
