Mono version (if Sonarr is not running on Windows): 6.12.0.122
OS: Raspberrian
Debug logs: https://www.toptal.com/developers/hastebin/raw/kirejidadi
After upgrading to v3, the connection to Plex no longer works with HTTPS. I found that the issue is related to the certificate validation of the HTTPS connection. When I change plex to SSL “Recommended” and turn off the option for HTTPS in Sonarr, it works fine, but I’m not fond of leaving traffic unencrypted. The certificate of the Plex system of course belongs to the plex.direct domain and not to my local internal IP address. So even though the certificate is valid, it’s not for the local server name/ip address. Is there a way to add an exception for a Plex URL that is internal, or must Plex HTTPS calls be routed over the internet (not ideal)?
No
So what you’re saying then is you believe your LAN network is not secure and is compromised?
Sounds like you have other issues then.
If that’s not the case then there is no point to connect devices over SSL on your LAN. If you truly insist on doing so then figure out how to properly generate signed certificates for local IP addresses…good luck.
Wow, thanks for that “help”. I meant I don’t like leaving Plex configured to not require secure connections.
Also, I don’t think it would help to have a self generated certificate for the internal domain/ip address since then that would override the plex one and I wouldn’t be able to access Plex outside the network. I know how to do this, it’s just not a valid solution.
You wish to pigeon hole yourself with your settings then idk what to tell you.
It’s not possible to do what you want without making something less secure.
You can disable cert validation in sonarr for local addresses
Sounds like what you really need is Plex to add a feature to split the secure connections setting into local and remote
That isn’t how it works, plex.direct domains for local IPs are direct to your local address (which is why DNS rebinding prevention can cause issues).
You have a few options:
- Use the full plex.direct domain
- Disable certificate validation for local IPs
- Use an “insecure connection” (http instead of https)
Disabling cert validation for internal addresses is exactly what I was looking for, but I couldn’t seem to find it in v3. Another helpful user showed me where it was under the General options page.
On the other hand, if you block(ed) external access in local setup Plex server (plex only to be uses internal network), why should you use encrypted connections? With regards to outgoing connectivity (from internal network to Plex.com itself) using secure VPN would do the trick.
