KAT mirror support and Onion extension
So, in a gradual fashion it looks like KickassTorrents is being blocked in my region.
I’ve tried changing the link from https://kat.cr to each of the mirror statute don kastatus.com
They work on & off, but I do keep having to change between them to find a working one.
2 questions:
  • Any chance of being able to enter them all in one field, without creating separate indexers for each mirror? (Comma separated, perhaps?)
  • Any chance of support for the .onion links from the dark web?
    Particularly: http://lsuzvpko6w6hzpnn.onion/
No plans to support that.
If you setup TOR on your system that should work fine, we don’t plan to implement TOR directly in Sonarr though.
For the comma separated, understandable.
For TOR, I’ve now installed it (on QNAP, which’ll put you off, but just imagine it as a unix install)
TOP is up & running, how do I get Sonarr to use it / flow through it?
