I’m having the same problem. https://kat.cr is working fine as i visite is with my normal browser. In sonarr I keep getting the same error: Indexers unavailable due to failures: KickassTorrents
Open KAT in a browser, no problems. Had an old Sonarr installation on a virtual Ubuntu - updated it to same version of Mono and Sonarr - KAT replies instantly.
Tried to re-install both Sonarr and Mono from scratch, no luck.
Just registered here to say that I was having the same issue. I changed the url to http:// instead of https:// and it started working again. Maybe this might work for you guy as well. I am running sonarr on my qnap as well.
Yeah I’ve had that happen a couple times already since I figured it out a couple days ago. But initiating a “test” and saving it generally fixes it. KAT needs to get their shit together for a real fix.
Same, sometimes disabling/enabling indexer helps, sometimes a restart of Sonarr helps, sometimes nothing helps. Seems to happen on & off (more time with issue than not), but I think it’s probably kat end.
Saw this in the log:
“utf-8”’ is not a supported encoding name.
