Judas Release Not Recognised
Sonarr version (exact version): 4.0.20.3014
Mono version (if Sonarr is not running on Windows): N/A – Sonarr v4 uses .NET rather than Mono.
OS: Ubuntu Server 26.04.1 LTS, running Sonarr in Docker (LinuxServer.io container).
Debug logs: Available. I’ve enabled debug logging and reproduced the issue multiple times. I’ll provide the full debug log through one of the recommended log-sharing services.
"2026-11-13 12:20:49.6
DownloadDecisionMaker:
Processing release ‘[Judas] JoJo’s Bizarre Adventure
(JoJo no Kimyou na Bouken) - S06E09’
from ‘Nyaa.si (Prowlarr)’
Release rejected for the following reasons:
[Permanent] Unknown Series"
Hi everyone,
I’m having an issue with Sonarr not recognising certain anime releases, specifically releases from Judas for JoJo’s Bizarre Adventure (2012).
I’ve configured Sonarr with custom formats that prioritise Judas and Ember releases, particularly 1080p HEVC releases with dual audio and multiple subtitles.
However, when searching for Season 6, Episode 9, the Judas release doesn’t appear in Sonarr’s interactive search results, despite being available on Nyaa.si.
I’ve confirmed that Prowlarr successfully finds the release and passes it to Sonarr.
The release is named:
[Judas] JoJo's Bizarre Adventure (JoJo no Kimyou na Bouken) - S06E09 [1080p][HEVC x265 10bit][Dual-Audio][Multi-Subs] (Weekly)
The series in Sonarr is:
JoJo's Bizarre Adventure (2012)
TVDB ID: 262954
After investigating Sonarr’s debug logs, I found that Sonarr receives and parses the release but rejects it with the following error:
The relevant debug messages are:
Episode Parsed. JoJo's Bizarre Adventure (JoJo no Kimyou na Bouken) - S06E09
SceneMappingService: Found scene mapping for:
JoJo no Kimyou na Bouken.
TVDB ID for mapping: 262954
ParsingService: No matching series
DownloadDecisionMaker: Release rejected:
Interestingly, Sonarr already recognises the following alternative titles:
  • JoJos Bizarre Adventure
  • JoJo no Kimyou na Bouken
Both are mapped to TVDB ID 262954 .
However, when Judas combines the English and Japanese titles in brackets, Sonarr appears unable to match the release to the existing series.
Troubleshooting completed:
  1. Confirmed that the release exists on Nyaa.si.
  2. Confirmed that Prowlarr finds the release correctly.
  3. Confirmed through Sonarr’s debug logs that Sonarr receives the release.
  4. Checked that the interactive search filter is set to All.
  5. Manually refreshed Sonarr’s scene mappings.
  6. Tested changing the series type from Standard to Anime, but this didn’t resolve the issue.
  7. Confirmed that other releases for the same episode are recognised correctly.
My question is whether this combined English/Japanese title needs an additional scene mapping, or whether there is another recommended way to make Sonarr recognise it.
Ideally, I’d like Sonarr to recognise these Judas releases automatically so that my existing custom-format preferences can handle future downloads and upgrades without manual intervention.
Any advice would be appreciated.
Thanks!
