Sonarr version (exact version): 3.0.6.1265
Mono version (if Sonarr is not running on Windows): Windows - 4.8.0
OS: Windows 10 Pro
2021-07-15 13:46:17.8|Info|NzbSearchService|Searching 2 indexers for [Jeopardy! : 2021-07-13]
2021-07-15 13:46:22.1|Info|DownloadDecisionMaker|Processing 2 releases
Description of issue: Jeopardy doesn’t download any files on USENET on a new install. When I do a manual search, for instance on 2021-07-13, it shows 2 releases, but it has the red exclamation and it says “Release Rejected: Episode wasn’t requested: 2021x8” for both.
The two releases listed are:
- Jeopardy.2021.01.13.720p.HDTV.x264-ForMagSmith9
- Jeopardy.2021.01.13.720p.HDTV.x264-60FPS
It’s set to Daily for the type, but I also tried Standard. This is a clean install of Sonarr on a new machine.
A friend verified that he is having the same issue on an existing Sonarr install that used to download Jeopardy fine.
