2.0.0.4645:
Windows 7 Pro
http://pastebin.com/DQqAV3XA
I cleared Debug Logs and performed simple automatic search with ONLY my Jackett torrent indexer enabled.
And to be clear, I’m using the proper torznab feed url from Jackett (not the potato one) and testing showed “succeeded”
If I search Manual or Automatic using ONLY my Jackett torrent indexer inside Sonarr, 0 results found.
If I search manually directly inside Jackett UI, desired results ARE found. Nothing strange with the Season/Episode going on here either. On the torrent site AND in Jackett UI, the search results contain the standard “S05E03” Season/Episode syntax.
