Sonarr version (exact version): 2.0.0.5054 Mono version (if Sonarr is not running on Windows): OS: windows 8.1 ((Debug logs)): https://pastebin.com/nHiK45jz (Make sure debug logging is enabled in settings and post the full log to hastebin/pastebin/dropbox/google drive or something similar, do not post them directly here) Description of issue:
it seems uTorrent is set up correctly as i get a "test successful’ pop up, but when i search for titles and they are marked as downloading, nothing is sent over to uTorrent.
After reading a few posts, i realized i cannot access uTorrent’s webUI. Everything is forwarded correctly. I get a invalid request. my uTorrent version is 3.2.2 28500.
The connection was rejected, usually caused by a firewall or uTorrent not running. The connection method for testing and communicating with uTorrent to add torrents/fetch the queue is the same.
uTorrent is running. windows firewall is off, the only other thing i had runing was malware bytes and i turned it off. still get the same thing. any ideas?
So, i just checked uTorrent and noticed i had more “downloads” than the last time i looked. Sonarr is now sending it over correctly…or more specific, uTorrent is now accepting them. I tried downloading a torrent manually and was having an issue (first time using uTorrnet, as i was having issues with other clients). After doing some reading, i changed a setting in uTorrent (where the .torrent files were to be saved) this seemed to fix my manually adding issue, along with the Sonarr issue.
Thanks for the replies!!!
now just to get the unrar issue im having figured out ha
