Sonarr version: 2.0.0.5134
Mono version: 5.4.1.6
OS: MacOS 10.13.2 (17C205)
Debug logs: https://pastebin.com/fqBpRUCe
Media files are being detected as samples.
When I run mediainfo directly from the cli I can see that very little information about the files is being returned.
$ mediainfo --version
MediaInfo Command line,
MediaInfoLib - v17.12
$ mediainfo A.P.Bio.S01E01.Pilot.Catfish.1080p.AMZN.WEB-DL.DDP5.1.H.264-NTb.mkv
General
Complete name : A.P.Bio.S01E01.Pilot.Catfish.1080p.AMZN.WEB-DL.DDP5.1.H.264-NTb.mkv
File size : 1.08 GiB
Is there a way to disable sample detection? or at least tell it to use filesize or some other metric?
Taloth
2
What is the file hash? (no guarantees you’ve got the exact same file, but check it)
$ sha1sum A.P.Bio.S01E01.Pilot.Catfish.1080p.AMZN.WEB-DL.DDP5.1.H.264-NTb.mkv
6541bf3ec0bcdf79f7dd6f23e2f783eaa1f6f206 A.P.Bio.S01E01.Pilot.Catfish.1080p.AMZN.WEB-DL.DDP5.1.H.264-NTb.mkv
I got mediainfo on that with both 0.7.91 and 17.12. If you don’t it’s likely a bad file or bad mediainfo version/install.
As for your other question, no, there’s no way to disable that.
I think you may be right about this particular file. I wasn’t able to get it to play on any device.
I have however had another file fail to import and be marked as a sample which does give proper information from mediainfo.
Debug log file: https://pastebin.com/5JXx5ZLr
$ shasum American.Dad.S14E23.Santa.Schmanta.720p.AMZN.WEB-DL.DD+5.1.H.264-SiGMA.mkv
a0edb7bdb56c2bbbb892d42518c4b004ad466ddc American.Dad.S14E23.Santa.Schmanta.720p.AMZN.WEB-DL.DD+5.1.H.264-SiGMA.mkv
$ mediainfo American.Dad.S14E23.Santa.Schmanta.720p.AMZN.WEB-DL.DD+5.1.H.264-SiGMA.mkv
General
Complete name : American.Dad.S14E23.Santa.Schmanta.720p.AMZN.WEB-DL.DD+5.1.H.264-SiGMA.mkv
Format : E-AC-3
Format/Info : Enhanced Audio Coding 3
File size : 295 MiB
Duration : 1 h 4 min
Overall bit rate mode : Constant
Overall bit rate : 640 kb/s
FileExtension_Invalid : dd+ ec3 eac3
Audio
Format : E-AC-3
Bit rate mode : Constant
Bit rate : 640 kb/s
Channel(s) : 6 channels
Channel positions : Front: L C R, Side: L R, LFE
Sampling rate : 48.0 kHz
Frame rate : 187.500 FPS (256 SPF)
Compression mode : Lossy
Stream size : 295 MiB
Service kind : Complete Main
system
Closed
4
