Sonarr version (exact version): 2.0.0.4689
OS: Windows 10
I previously had Sonarr and SAB working really nicely together. Since a recent SAB update i have had to reinstall SAB on a new Windows 10 machine (it was previously running on my Synology NAS - which is where Sonarr is also running).
I am running into an issue (which might just be a configuration issue on my part, so that’s what I am hoping you can help me with). The problem is that i get an error “not a valid path, might need to use Remote Folder Mapping”.
My configuration is as follows:
In SAB, i have a category defined for Sonarr called ‘sonarr’. For this category, i have the path defined as the Media directory for TV shows. This directory is a windows network mount (\\192.168.1.9\Media -> Z:\) and i use Z:\TV Shows in this configuration item. For the Temporary Download Folder in SAB i have it set to what i believe to be the default, of ‘temporary\incomplete’ with Completed Download Folder set to ‘Downloads\complete’. After downloading 1 TV episode i find the file in that location. My thought was that Sonarr would pick up this download, and move it to the my media directory. So am i setting a configuration wrong here? Should my category for ‘Sonarr’ path be configured to be Z:/TV Shows/? I can navigate via windows Explorer to that directory and view all its contents as well as read/write (create folders and files manually through the UI).
Any thoughts, comments, suggestions would be hugely appreciated. I hope this isn’t just a simple mis-config in one of the two apps. But that seems like the most likely option of them all at this rate.
Thanks
