Issues with folders randomly changing
Sonarr version (3.0.9.1549):
Mono version (6.12.0.182):
OS:Unraid
[Debug logs] 2023-03-07 12:43:07.0|Warn|ImportApprovedEpisodes|Couldn't import episode /data/ - Pastebin.com:
Running:
Unraid 6.11.5
Sonarr 3.0.9.1549
Deluge 2.1.1
So yesterday I had everything set up between Sonarr and Deluge and was able to run some tests where i would download a file, it would finish and it would move into its appropriate folder. All is well.
Today out of curiosity I did another test, requested a download and waited for it to finish to ensure it was all still working correctly. For some reason its been broken overnight. The file is staying in Deluge in a “Paused” State, the file isnt moving and Sonarr is giving me the following error under the status tab saying "Missing Root Folder: /data/torrents/shows. The pastebin above also shows errors pointing to this folder.
The odd part is, /data/torrents/Shows is not a directory i am using anywhere.
My Directories are as follows:
/mnt/user/data/torrents/
/mnt/user/data/media/movies/
/mnt/user/data/media/tv/
Deluge downloads into /mnt/user/data/torrents
Sonarr should move these into /mnt/user/data/media/tv/“Respective show folder”
i have no idea where this “/data/torrents/Shows” error is coming from.
Here are some images of my folder setups:
Deluge download configuration:
Deluge downloads settings:
Sonarr path:
Sonarr Root Folders:
I have nothing under “Remote Path Mappings” in the Download Clients Setting page.
Can anyone help me out? Let me know if i need to provide any other information.
Thanks
