Sonarr version (exact version): 2.0.0.5322
OS: Windows 10
I’ve newly configured Sonarr, I have it running in my startup folder, I use a Drobo NAS and I’m using the UNC path to these directories. I’ve added a show, and went under the Wanted and forced it to search for the whole season to test it and see if I could get it working.
It now has all 9 episodes in the activity but there are errors in the logs for failure to import directory
“Import failed, path does not exist or is not accessible by Sonarr: \drobo5n\share1\Unsorted\Doom.Patrol.S01E03.720p.HEVC.x265-MeGusta”
I don’t understand why this is, now it eventually gave me an error under “System” saying missing root folder: \Drobo5n\share1\Test which is the directory where I want the downloaded files to be moved to once finished.
it seems to be a permission issue or an issue with Sonarr not being able to see that directory but I don’t understand because I started it in the startup folder which is meant to make this work.
Debug logs, I only just turned it on after reading the info below.
https://pastebin.com/v17ywB83
