Issue with Sonarr not importing first 3 episodes of a season
OS: linux gentoo 5.4.31
Debug logs: https://www.dropbox.com/s/m230a3m3ay2c922/sonarr.debug.0.txt?dl=0
Steven Universe season 2 is having issues for some reason. I’ve tried 2 different torrents (full seasons) but the first 3 episodes are not importing. The file names are the same for all episodes. I am not seeing any errors, episodes are just missing from disk but the other 26 episodes in the season imported just fine. If I go to Activity then History, there is nothing there indicating a failed import, so not sure what’s going on?
Thanks for all your hard work with sonarr :smiley:
20-4-16 16:24:32.7|Debug|ParsingService|Using Scene to TVDB Mapping for: Steven Universe - Scene: 2x01 - TVDB: 2x04
steven.universe.s02e01.1080p.bluray.x264-taxes will import as season 2 episode 4 due to that XEM mapping.
If that folder is actually following TVDB numbering you’ll want to use Manual Import on Wanted: Missing to import it and override Sonarr’s episode selection.
Thanks for your response! Manual import worked. :smiley:
