Issue with restoration of backup
Sonarr version (exact version): Version 2.0.0.5322
OS: Windows 10
Logs: https://pastebin.com/tyWMCqj8
Description of issue: On reboot of PC windows stated that it was unable to launch sonnarr due to corruption of XML. I re-installed sonarr as per the github directions on backup and restore and then deleted the files from the appdata folder, replacing them with the backups in the backup from 31st of last month. On re-launching sonarr, it is showing in a pre-configured state without any of the settings / libraries or any of the information it should show.
You shouldn’t need to restore anything except the config.xml file in that case and even then you could just delete the config file and setup for few settings that are in there (auth being the main one).
Which files did you restore?
