I love Sonarr, have been using it on Windows for a while and am in the process of migrating all my usenet services onto an Ubuntu 14.04 server. The files themselves are hosted on a Synology NAS shared via samba. I have been doing my best google searching to try and find a solution but so far have had no luck. The first thing I did was try and make sure I was mounting my share properly, my fstab contains the following mount command:
//10.10.10.4/Multimedia /media/multimedia cifs credentials=/home/docker/.smbcreds,iocharset=utf8,rw,nounix,file_mode=0777,dir_mode=0777,uid=1000,gid=1000 0 0
This finally gave me the permissions that I thought would enable Sonarr to work:
2228258 drwxrwxrwx 2 docker docker 0 Feb 5 16:18 Television
However I still get this error message:
Message
Request Failed: Root folder path ‘/media/multimedia/Television/’ is not writable by user ‘docker’
Exception
System.UnauthorizedAccessException: Root folder path ‘/media/multimedia/Television/’ is not writable by user 'docker’
at NzbDrone.Core.RootFolders.RootFolderService.Add (NzbDrone.Core.RootFolders.RootFolder rootFolder) [0x0014f] in m:\BuildAgent\work\6c3239faf2b92630\src\NzbDrone.Core\RootFolders\RootFolderService.cs:123
at NzbDrone.Api.NzbDroneRestModule1[TResource].GetNewId[TModel] (System.Func2 function, NzbDrone.Api.TResource resource) [0x0000c] in m:\BuildAgent\work\6c3239faf2b92630\src\NzbDrone.Api\NzbDroneRestModule.cs:31
at NzbDrone.Api.RootFolders.RootFolderModule.CreateRootFolder (NzbDrone.Api.RootFolders.RootFolderResource rootFolderResource) [0x00000] in m:\BuildAgent\work\6c3239faf2b92630\src\NzbDrone.Api\RootFolders\RootFolderModule.cs:45
at NzbDrone.Api.REST.RestModule1[TResource].<set_CreateResource>b__f (System.Object options) [0x00000] in m:\BuildAgent\work\6c3239faf2b92630\src\NzbDrone.Api\REST\RestModule.cs:155 at (wrapper dynamic-method) System.Object:CallSite.Target (System.Runtime.CompilerServices.Closure,System.Runtime.CompilerServices.CallSite,System.Func2<object, object>,object)
at Nancy.Routing.Route+<>c__DisplayClass4.b__3 (System.Object parameters, CancellationToken context) <0x41eeee80 + 0x0014f> in :0
After reading a lot of the posts on this forum I decided to try creating a symlink and trying again which gives the same error message. Has anyone successfully overcome this type of error? Any help is appreciated. Thanks.
