Hi! I have tried to get support in discord but I think that this channel is more appropiate in case someone can be affected for this “issue” too.
The problem is common, yhe typical message “Import failed, path does not exist or is not accessible by Sonarr:”
I use QNAP + Sonar (2.0.0.5344) + qBittorrent
I have checked that qBittorrent stores the file using the same group/user than Sonar.
The only think I see is that the message says: “Import failed, path does not exist or is not accessible by Sonarr: /share/Download/completed/tv-sonarr/Designated.Survivor.S01E19.720p.HDTV.x264-KILLERS” But… the extension of the file is missing
Could that be the issue? Not all files downloaded are compressed and none is imported propperly, so I do not know what could be.
Thanks in advance.
