Hi, I am creating a script in bash, but I can’t figure out if I can set a monitor/unmonitor season, not the individual episodes but the season itself.
If I try with this:
curl -X PUT "${sonarr_host}:${sonarr_port}/api/v3/series/${show_id}" \
-H "accept: text/plain" \
-H "Content-Type: application/json" \
-H "X-Api-Key: ${sonarr_api}" \
--data-raw '{
"qualityProfileId": '"$qualityProfileId"',
"path": "'"$path"'",
"seasons": [
"seasonNumber": '"$season_number"',
"monitored": false
I get error because path and profileid is missing, if I then add it and run:
--data-raw '{
"seasons": [
"monitored": false
it happens that in the tv show I get only the edited season, for example season 5, monitored or unmonitored, and all other seasons disappear
Is there any way, to put only one season under monitor/unmonitor?
