Interactive episode search problems
Sonarr version (exact version): 3.0.3.885
Mono version (if Sonarr is not running on Windows):5.20.1.34
OS: Debian using Docker
(Make sure debug logging is enabled in settings and post the full log to hastebin/pastebin/dropbox/google drive or something similar, do not post them directly here. Post in .txt not .doc, .rtf or some other formatted document) https://hastebin.com/givugituxe.rb https://hastebin.com/nuwiluseva.cs https://hastebin.com/kepoyojoya.rb
Description of issue: So after doing a manual search i get this error Unable to load results for this episode search. Try again later.
It sometimes clears itself after a few hours, but restarting the container is an immediate temp fix.
Anyone got any ideas? it might be something to do with my nzbhydra container, but no idea where to start.
In the 54 seconds your debug log covers I see a request to NZB Hydra and Jackett, but neither of them respond.
Best guess you’re using a reverse proxy and the request is timing out before Sonarr gets the results back so the UI just gets an error back.
