Integrate with srrDB
Hi,
Using srrDB drone could search the crc of a episode and get the original release name of the episode.
This will be especially useful when adding in existing shows. Sometime its difficult to check if the episode is a hdtv rip or a dvdrip etc. if its not included in the name. In that case drone can calculate the crc value and search srrdb and get the original release name and check if its a dvdrip or hdtv etc.
srrDB has an api which should make things easier. http://www.srrdb.com/help
for example:
http://www.srrdb.com/api/search/archive-crc:4BDAC0BE
Which gives the original release name which in this case is Burn.Notice.S03E01.PROPER.RETAIL.DVDRip.XviD-REWARD
Any update?
It would be great if this was added
Please don’t follow up asking for updates. I didn’t have time to look into it when it first came in, but I flagged it for something to look at later. I’ll update when I have time to research it and determine whether or not its something we want to do.
Though I should have at least said we’ll look into that, sorry I neglected to do so.
This is really interesting, I’ve been looking for something like this for a while, even considered rolling our own database. I’ll take a look but as mark said we’ll have to do some research and run some tests to see how reliable their data is.
