Indexers fail until restarted
Sonarr version (exact version): 1.3.3
Mono version (if Sonarr is not running on Windows): 4.0.17.2950
OS: Truenas 25.10.0.1 - Goldeye
Was unable to fit all logs in this post so I found anything I thought might be relevant. Any spacing indicates moving to another section of the logs.
Have started having an issue where all of my indexers will begin to fail for no reason that I can identify. Sonarr will only be able to reconnect to them if I restart the app in the Truenas GUI. This issue started maybe a month ago and I brushed it off until it continued to get worse. From my knowledge, the intexers I have paid access to have no limit on the pulls that I request. Below are the logs that I found where it seems to start failing. Would appreciate any insight on this issue.
2026-03-24 08:47:30.3|Warn|Newznab|NZBgeek server is currently unavailable. https://api.nzbgeek.info/api?t=tvsearch&cat=5030,5040&extended=1&apikey=(removed)&offset=0&limit=100&tvdbid=146711&rid=25591&tvmazeid=177&season=1 Http request timed out
2026-03-24 08:47:30.3|Warn|Newznab|altHUB server is currently unavailable. https://api.althub.co.za/api?t=tvsearch&cat=5030,5040&extended=1&apikey=(removed)&offset=0&limit=100&tvdbid=146711&imdbid=tt1578873&rid=25591&tvmazeid=177&season=1 Http request timed out
[v4.0.17.2950] System.Net.WebException: Http request timed out
at NzbDrone.Common.Http.Dispatchers.ManagedHttpDispatcher.GetResponseAsync(HttpRequest request, CookieContainer cookies) in ./Sonarr.Common/Http/Dispatchers/ManagedHttpDispatcher.cs:line 144
at NzbDrone.Common.Http.HttpClient.ExecuteRequestAsync(HttpRequest request, CookieContainer cookieContainer) in ./Sonarr.Common/Http/HttpClient.cs:line 157
at NzbDrone.Common.Http.HttpClient.ExecuteAsync(HttpRequest request) in ./Sonarr.Common/Http/HttpClient.cs:line 70
at NzbDrone.Common.Http.HttpClient.DownloadFileAsync(String url, String fileName) in ./Sonarr.Common/Http/HttpClient.cs:line 311
at NzbDrone.Common.Http.HttpClient.DownloadFile(String url, String fileName) in ./Sonarr.Common/Http/HttpClient.cs:line 316
at NzbDrone.Core.Extras.Metadata.MetadataService.DownloadImage(Series series, ImageFileResult image) in ./Sonarr.Core/Extras/Metadata/MetadataService.cs:line 505
β€”> System.IO.IOException: Unable to read data from the transport connection: Operation canceled.
β€”> System.Net.Sockets.SocketException (125): Operation canceled
β€” End of inner exception stack trace β€”
at System.Net.Sockets.Socket.AwaitableSocketAsyncEventArgs.ThrowException(SocketError error, CancellationToken cancellationToken)
at System.Net.Sockets.Socket.AwaitableSocketAsyncEventArgs.System.Threading.Tasks.Sources.IValueTaskSource<System.Int32>.GetResult(Int16 token)
at System.Net.Http.HttpConnection.InitialFillAsync(Boolean async)
at System.Net.Http.HttpConnection.SendAsyncCore(HttpRequestMessage request, Boolean async, CancellationToken cancellationToken)
at NzbDrone.Common.Http.HttpClient.Execute(HttpRequest request) in ./Sonarr.Common/Http/HttpClient.cs:line 128
at NzbDrone.Core.Notifications.Xbmc.XbmcJsonApiProxy.ProcessRequest(XbmcSettings settings, String method, Object parameters) in ./Sonarr.Core/Notifications/Xbmc/XbmcJsonApiProxy.cs:line 78
at NzbDrone.Core.Notifications.Xbmc.XbmcJsonApiProxy.CleanLibrary(XbmcSettings settings) in ./Sonarr.Core/Notifications/Xbmc/XbmcJsonApiProxy.cs:line 59
at NzbDrone.Core.Notifications.Xbmc.XbmcService.Clean(XbmcSettings settings) in ./Sonarr.Core/Notifications/Xbmc/XbmcService.cs:line 58
at NzbDrone.Core.Notifications.Xbmc.Xbmc.b__19_1(UpdateQueueItem1 item) in ./Sonarr.Core/Notifications/Xbmc/Xbmc.cs:line 130 at System.Collections.Generic.List1.ForEach(Action1 action) at NzbDrone.Core.Notifications.MediaServerUpdateQueue2.ProcessQueue(String identifier, Action`1 update) in ./Sonarr.Core/Notifications/MediaServerUpdateQueue.cs:line 79
at NzbDrone.Core.Notifications.NotificationService.ProcessQueue() in ./Sonarr.Core/Notifications/NotificationService.cs:line 559
2026-03-24 08:47:35.3|Debug|IndexerFactory|Temporarily ignoring indexer NZBgeek till 03/24/2026 08:48:30 due to recent failures.
2026-03-24 08:47:35.3|Debug|IndexerFactory|Temporarily ignoring indexer altHUB till 03/24/2026 08:48:30 due to recent failures.
2026-03-24 08:47:58.4|Debug|Sonarr.Http.Authentication.ApiKeyAuthenticationHandler|AuthenticationScheme: API was not authenticated.
2026-03-24 08:48:01.9|Debug|Sonarr.Http.Authentication.ApiKeyAuthenticationHandler|AuthenticationScheme: API was successfully authenticated.
2026-03-24 08:48:01.9|Debug|Api|[GET] /api/v3/health: 200.OK (1 ms)
2026-03-24 08:48:21.6|Debug|ImportListSyncService|No import lists with automatic add enabled
2026-03-24 08:48:22.5|Debug|Sonarr.Http.Authentication.ApiKeyAuthenticationHandler|AuthenticationScheme: API was successfully authenticated.
2026-03-24 08:48:22.5|Debug|Api|[GET] /api/v3/command: 200.OK (1 ms)
2026-03-24 08:48:28.5|Debug|Sonarr.Http.Authentication.ApiKeyAuthenticationHandler|AuthenticationScheme: API was not authenticated.
2026-03-24 08:48:51.6|Debug|SabnzbdProxy|Url: http://192.168.1.192:30055/api?mode=queue&start=0&limit=0&category=tv&apikey=(removed)&output=json
2026-03-24 08:48:51.6|Debug|SabnzbdProxy|Url: http://192.168.1.192:30055/api?mode=history&start=0&limit=60&category=tv&apikey=(removed)&output=json
2026-03-24 08:52:39.1|Debug|IndexerFactory|Temporarily ignoring indexer Nzb.su till 03/24/2026 09:07:33 due to recent failures.
2026-03-24 08:52:40.4|Debug|Sonarr.Http.Authentication.ApiKeyAuthenticationHandler|AuthenticationScheme: API was successfully authenticated.
2026-03-24 08:52:40.4|Debug|Api|[GET] /api/v3/health: 200.OK (1 ms)
2026-03-24 08:52:51.7|Info|RssSyncService|Starting RSS Sync
2026-03-24 08:52:51.8|Debug|IndexerFactory|Temporarily ignoring indexer Nzb.su till 03/24/2026 09:07:33 due to recent failures.
2026-03-24 08:52:51.8|Debug|FetchAndParseRssService|Available indexers 3
2026-03-24 08:52:51.8|Debug|Newznab|Downloading Feed https://api.nzbgeek.info/api?t=tvsearch&cat=5030,5040,5000,5070&extended=1&apikey=(removed)&offset=0&limit=100
2026-03-24 08:52:51.8|Debug|Newznab|Downloading Feed Anime Tosho
2026-03-24 08:52:51.8|Debug|Newznab|Downloading Feed https://api.althub.co.za/api?t=tvsearch&cat=5030,5040,5000,5070&extended=1&apikey=(removed)&offset=0&limit=100
2026-03-24 08:52:59.2|Debug|Sonarr.Http.Authentication.ApiKeyAuthenticationHandler|AuthenticationScheme: API was not authenticated.
2026-03-24 08:53:29.3|Debug|Sonarr.Http.Authentication.ApiKeyAuthenticationHandler|AuthenticationScheme: API was not authenticated.
2026-03-24 08:53:59.4|Debug|Sonarr.Http.Authentication.ApiKeyAuthenticationHandler|AuthenticationScheme: API was not authenticated.
2026-03-24 08:54:21.2|Error|Sabnzbd|Downloading nzb for episode β€˜Pretty.Little.Liars.S01E01.Pilot.1080p.WEB-DL.DD5.1.H.264-NTb’ failed (NZB.life - Login System.Net.WebException: Http request timed out
at NzbDrone.Common.Http.HttpClient.ExecuteAsync(HttpRequest request) in ./Sonarr.Common/Http/HttpClient.cs:line 96
at NzbDrone.Core.Download.UsenetClientBase1.<>c.<<Download>b__6_0>d.MoveNext() in ./Sonarr.Core/Download/UsenetClientBase.cs:line 53 --- End of stack trace from previous location --- at Polly.ResiliencePipeline.<>c__92.<b__9_0>d.MoveNext()
β€” End of stack trace from previous location β€”
at Polly.Outcome1.GetResultOrRethrow() at Polly.ResiliencePipeline.ExecuteAsync[TResult,TState](Func3 callback, TState state, CancellationToken cancellationToken)
at NzbDrone.Core.Download.UsenetClientBase`1.Download(RemoteEpisode remoteEpisode, IIndexer indexer) in ./Sonarr.Core/Download/UsenetClientBase.cs:line 90
I am thinking I figured out the solution to this if anyone else is having issues with it. Nothing is the logs are really going to help with this from what I am seeing. The major issue was with connection to the server and Sonarr. My old switch appeared to be dying to all of my connection were a lot slower than expected. Upon changing out my switch, seems to have fixed to issue.
