I have sabnzbd set up in sonarr clients.
I have added 3 indexers NZBGeek, wombles and Fanzub
after adding each indexer if i try to test with the search switch on i get unable to connect
if i turn both rss and search switches off test passes. doesn’t seem to matter what indexer I try always same issue. anyone have an idea where to look?
this line below bothers me and no idea why it is being refused
System.Net.Sockets.SocketException: No connection could be made because the target machine actively refused it 127.0.0.1:49306
Log:
Invalid request Validation failed:
– Unable to connect to indexer, check the log for more details
Message
Unable to connect to indexer: Unable to connect to the remote server: Unable to connect to the remote server
Exception
System.Net.WebException: Unable to connect to the remote server —> System.Net.Sockets.SocketException: No connection could be made because the target machine actively refused it 127.0.0.1:49306
at System.Net.ServicePoint.ConnectSocketInternal(Boolean connectFailure, Socket s4, Socket s6, Socket& socket, IPAddress& address, ConnectSocketState state, IAsyncResult asyncResult, Exception& exception)
at System.Net.HttpWebRequest.GetResponse()
at NzbDrone.Common.Http.HttpClient.Execute(HttpRequest request) in m:\BuildAgent\work\6c3239faf2b92630\src\NzbDrone.Common\Http\HttpClient.cs:line 94
at NzbDrone.Core.Indexers.HttpIndexerBase1.FetchPage(IndexerRequest request, IParseIndexerResponse parser) in m:\BuildAgent\work\6c3239faf2b92630\src\NzbDrone.Core\Indexers\HttpIndexerBase.cs:line 195 at NzbDrone.Core.Indexers.HttpIndexerBase1.TestConnection() in m:\BuildAgent\work\6c3239faf2b92630\src\NzbDrone.Core\Indexers\HttpIndexerBase.cs:line 211
