Sonarr version (exact version): 2.0.0.5338 OS: Windows 10 1909 - fully patched
I have 2 indexers running on Sonarr. DogNZB and NZBGeek. DogNZB test and runs just fine, but NZBGeek fails with some TLS version issues.
I’ve seen others say that updating windows to patch .NET solved some issues. Windows 10 finished fully patching and after a reboot, still get the same errors. Debug logs are attached: https://pastebin.com/2y26jhtj
I’m also curious about an initial error during the startup of sonar. It reads:
SecurityProtocolPolicy: Disabled TLS 1.2 due to remote certificate error. Not sure if that is just relating to the local certificate or something to do with the certificate connecting to the indexer?
If you disable SABnzbd and restart Sonarr does the test still fail? It looks like that is the reason TLS 1.2 is disabled, you’ll want to use HTTP or fix the cert if that’s the case
