Sonarr Version: 3.0.4.1069
Package Version: 3.0.4.1069-ls28 by linuxserver.io
Mono Version: 5.20.1.34
Ubuntu 20.04:
Description of issue: One Index has automatic search disabled however Sonarr is regularly grabbing from this index and seems to be ignoring this setting.
I have just started using this setting in Sonarr, I use the same setting in Radarr and it works correctly so suspect this is a bug/regression?
a lot of people dont realise that rss feeds are the only way soanrr can download something all by itself.
it never proactively searches for anything. episodes must be found in the rss feed for sonarr to do its thing.
that would be searches where you manually told sonarr to search the indexers for something but you dont want to manually select from the results (non interactive). eg, the magnifying glass icon next to an episode
manual (interactive) searches are where you manually told sonarr to search the indexers for something and you want to manually select from the results. eg, the person icon next to an episode, or the search tab for an episode.
RSS search is where sonarr (you cant initiate them) searches the rss feeds the indexers generate. this is the search it uses to find and download your monitored episodes in the background.
