Been using Sonarr on Mac via Docker for about a two years which has been pretty slick, where the one down point has been in the indexers and I never went in to tweak and update the indexers.
Migrating the docker media services to Synology and time to give the indexers some TLC.
What are your favorite free indexers (tv/movies including older content?)
Considering Usernet and interested in recommendations to help sift through the sea of reviews that conclude in little direction. Allergic to subscriptions and open to purchasing a lifetime option or two. Notice some indexers are invite only ~ invites appreciated.
ATM, process for me is to get information from Jackett, set up each in sonarr and radarr. Each configuration takes a fair amount of time and seems repetitive. Are there tools to make this go faster?
setup an indexer for all of jackett - eg http://jackett:9117/api/v2.0/indexers/all/results/torznab/
that way you can add/remove indexers to/from jackett whenever you like and you dont have to touch sonarr
but, you only get the standard categories (or at least did the last time i looked) so if one of your indexers uses a custom category for something you want then you will need to also add an indexer entry for that one as well, but only for the custom category, the standard ones will be covered under the jackett indexer entry.
just dont forget to change the jacket:9117 part to whatever yours needs. simplest is to just copy any current jackett indexers url and replace the name with all so it works in your situation.
Thought I had it working… just one indexer for sonarr that points to Jackett and testing indicates indexing is working for sonarr. Mind elaborating further on copying indexer urls?
in jackett you click on the copy torznab feed button to get the link for that indexer. i get this; http://jackett.home/api/v2.0/indexers/limetorrents/results/torznab/
and you just change the indexer name to all to get http://jackett.home/api/v2.0/indexers/all/results/torznab/
in my case though jackett is behind a reverse proxy, and its in docker as is the sonarr. they are both on the same container network though, so to make that link work i have to change the host part from jackett.home to jackett:9117.
what, and even if, you have to change it to will depend on your setup.
Thank you. Exploring prowler. Wondering if there is a script of compose style file that could be used for indexers, seems so manual.
Update - Prowler appears to working well.
Terms of indexers and Usenet, does anyone have recommendations? Subscription allergic, albeit open to possibility of purchasing lifetime access for a Usenet spot or two, and open to invites.
Probably better suited to finding the answers you seek, including plenty of people who have already asked about similar recommendations. Just a word of warning, for pretty much any decent private indexer, you’re looking at a subscription. And for actual usenet access it’s subscription or blocks only.
