Sonarr version (exact version): 4.0.0.452-ls452 by linuxserver.io
OS: Docker
After following a guide on how to rename folders, by remapping the Root folder to the same Root folder and specifying to Replace Illegal Characters. Instead of replacing “:” with “-” they have been replaced by " -" with does mesh with the naming convention that has been adopted.
Is this a consquence of using a linuxserver.io image of Sonarr?
Is there a way to fix this and why doesn’t Sonarr have the same character replace function as Radarr, where you can just select how to replace your colons?
