Sonarr: 3.0.8.1507
Windows 11 Pro
[v3.0.8.1507] System.IO.IOException: The process cannot access the file ‘Y:\Television\Legendary\Season 3\Legendary.S03E07.1080p.WEB.h264-KOGi.mkv’ because it is being used by another process.
at System.IO.FileStream.Init(String path, FileMode mode, FileAccess access, Int32 rights, Boolean useRights, FileShare share, Int32 bufferSize, FileOptions options, SECURITY_ATTRIBUTES secAttrs, String msgPath, Boolean bFromProxy, Boolean useLongPath, Boolean checkHost)
at System.IO.FileStream…ctor(String path, FileMode mode, FileAccess access)
at NzbDrone.Common.Disk.DiskProviderBase.OpenReadStream(String path) in M:\BuildAgent\work\63739567f01dbcc2\src\NzbDrone.Common\Disk\DiskProviderBase.cs:line 415
at NzbDrone.Core.MediaFiles.MediaInfo.VideoFileInfoReader.GetMediaInfo(String filename) in M:\BuildAgent\work\63739567f01dbcc2\src\NzbDrone.Core\MediaFiles\MediaInfo\VideoFileInfoReader.cs:line 59
I cant seem to get it to import the downloaded files… Permissions are correct, paths are correct…Log bof it is above but i cant work it out Any assistance would be appreciated
