Just ran into this error on 2 new imports from Sabnzbd
Couldn't import episode /mnt/downloads/tvshows/SpongeBob.SquarePants.S13E19.C.H.U.M.S.WEBDL.1080p.h264-S1PH3R.1/sGLKZ7f0ki2PV2hrnqCzH1: The string can't be left empty, null or consist of only whitespaces.
Parameter name: extension
Would be nice if it gave us the option to define a extension or used a best guess from keywords in the file name.
e.g. h264 = either avi or mkv
Also even if it were to get the extension wrong, most media players now would still be able to decode/play it as they generally dont require an ext to identify the codec/video type.
Basically requesting a “Best Guess” autofill option, and/or a field when importing files like these where we can specify one
