Version 2.0.0.5243
Windows 10 Pro x64.
Message from error log:
Import failed, path does not exist or is not accessible by Sonarr: Q:\downloads\XXXXXX.S02E02.WEB.x264-TBS[rarbg]
- Torrent box is on HTPC.
- Sonarr is on PMS.
- Sonarr service is running with login credentials with admin rights
- HTPC (torrent) downloads to a local folder, G:\Downloads located on PMS. This drive is mapped as Q on HTPC.
A couple of things have been tried with Remote Path Mappings. I have tried this:
https://imgur.com/IzbNGFv
Then I figured maybe Sonarr had to have the same remote path as the HTPC, so I used the SUBST command to create a virtual Q: Drive on PMS
https://imgur.com/e3wgAkF
The error message is always the same, Import failed, path does not exist.
