Version 2.0.0.5344
Mono Version 5.20.1.34
AppData directory /config
Startup directory /app/sonarr/bin
logfile
Import failed, path does not exist or is not accessible by Sonarr: /volume1/movies and shows/download/The.100.S07E16.WEB.h264-BAE[rarbg]
Hi,
Sorry i am pretty new to docker etc. I tried to configure this myself, got as far as to being able to download the shows i want, but during rename it fails with above error
In short, i have a synology nas, use downloadstation to download everything. I have tried setting this folder to being able to been read/write by every user, group, folder permissions etc. I have looked on google and i see many posts but my knowledge is too limited, sorry. I don’t know what to do next.
Can you plz advise what stupid mistake I made and how to fix it?
Sonarr doesn’t know about /volume1 it only knows about the paths you’ve provided it. Either use a remote path mapping in Sonarr or make it so Sonarr can access /volume1
In general you should keep downloads and sorted shows in the same volume in docker so you can utilize hardlinking for seeding torrents and atomic moves otherwise.
Ok, i have tried to read the text to my best of abilities. i understand i think that i should use a user in sonarr/radarr, even though this user appears to be the admin (101)
Ty, it is becoming a bit clearer. How do i adjust the remote path? i have to use “select folder” and that does not allow me to add **"/volume1/"**movies and shows/download/
That’s an artificial limitation of docker on synology, you can only select shared folders. You can get around it with docker-compose or you need to use a remote path mapping in Sonarr to translate the path.
I set the remote path mappings. I am not getting the errors I got before, but now the file still isn’t moved ;-( I waited for over an hour, but nothing appears to be happening once the download is complete
Update: Nvm, it works!!! TY so much! The problem i had now that i was redownloading an old episode which had a lower quality for testing purposes, but sonarr stated it will not copy due to that. added new show and that works!
