Debug logs isnt really showing anything weird I think, but here it is:
\ProgramData\NzbDrone\bin\nzbdrone.console.exe - Version 2.0.0.4146
16-6-8 14:52:56.0|Info|Bootstrap|Starting Sonarr - C:\ProgramData\NzbDrone\bin\nzbdrone.console.exe - Version 2.0.0.4146
16-6-8 14:52:58.1|Info|Bootstrap|Starting Sonarr - C:\ProgramData\NzbDrone\bin\nzbdrone.console.exe - Version 2.0.0.4146
16-6-8 14:52:58.4|Debug|ServiceProvider|Checking if service NzbDrone exists.
16-6-8 16:38:37.2|Info|Bootstrap|Starting Sonarr - C:\ProgramData\NzbDrone\bin\NzbDrone.exe - Version 2.0.0.4146
16-6-8 17:24:58.2|Info|Bootstrap|Starting Sonarr - C:\ProgramData\NzbDrone\bin\nzbdrone.console.exe - Version 2.0.0.4146
16-6-8 17:25:28.9|Info|Bootstrap|Starting Sonarr - C:\ProgramData\NzbDrone\bin\nzbdrone.console.exe - Version 2.0.0.4146
16-6-8 17:25:42.5|Info|Bootstrap|Starting Sonarr - C:\ProgramData\NzbDrone\bin\NzbDrone.exe - Version 2.0.0.4146
16-6-8 17:26:51.4|Info|Bootstrap|Starting Sonarr - C:\ProgramData\NzbDrone\bin\nzbdrone.console.exe - Version 2.0.0.4146
16-6-8 17:26:51.6|Debug|ServiceProvider|Checking if service NzbDrone exists.
and from the normal LOG file some text (all the same):
16-6-8 19:27:18.9|Warn|ImportApprovedEpisodes|Couldn’t import episode E:\Complete\SabSeries\The.Walking.Dead.S06E15.1080p.WEB-DL.DD5.1.H.264-Cyphanix\WrqrBC6uW4H9yb2Z09UVzT4cLggkt1Qk; )=;); )\wicked post.mkv
[v2.0.0.4146] System.NotSupportedException: The given path’s format is not supported.
at System.Security.Permissions.FileIOPermission.QuickDemand(FileIOPermissionAccess access, String fullPath, Boolean checkForDuplicates, Boolean needFullPath)
at System.IO.FileInfo.Init(String fileName, Boolean checkHost)
at System.IO.FileInfo…ctor(String fileName)
at NzbDrone.Common.Extensions.PathExtensions.CleanFilePath(String path) in M:\BuildAgent\work\6c3239faf2b92630\src\NzbDrone.Common\Extensions\PathExtensions.cs:line 30
at NzbDrone.Common.Extensions.PathExtensions.PathEquals(String firstPath, String secondPath, Nullable1 comparison) in M:\BuildAgent\work\6c3239faf2b92630\src\NzbDrone.Common\Extensions\PathExtensions.cs:line 48 at NzbDrone.Common.Disk.DiskTransferService.TransferFile(String sourcePath, String targetPath, TransferMode mode, Boolean overwrite, DiskTransferVerificationMode verificationMode) in M:\BuildAgent\work\6c3239faf2b92630\src\NzbDrone.Common\Disk\DiskTransferService.cs:line 107 at NzbDrone.Common.Disk.DiskTransferService.TransferFile(String sourcePath, String targetPath, TransferMode mode, Boolean overwrite, Boolean verified) in M:\BuildAgent\work\6c3239faf2b92630\src\NzbDrone.Common\Disk\DiskTransferService.cs:line 90 at NzbDrone.Core.MediaFiles.EpisodeFileMovingService.TransferFile(EpisodeFile episodeFile, Series series, List1 episodes, String destinationFilePath, TransferMode mode) in M:\BuildAgent\work\6c3239faf2b92630\src\NzbDrone.Core\MediaFiles\EpisodeFileMovingService.cs:line 118
at NzbDrone.Core.MediaFiles.EpisodeFileMovingService.MoveEpisodeFile(EpisodeFile episodeFile, LocalEpisode localEpisode) in M:\BuildAgent\work\6c3239faf2b92630\src\NzbDrone.Core\MediaFiles\EpisodeFileMovingService.cs:line 78
at NzbDrone.Core.MediaFiles.UpgradeMediaFileService.UpgradeEpisodeFile(EpisodeFile episodeFile, LocalEpisode localEpisode, Boolean copyOnly) in M:\BuildAgent\work\6c3239faf2b92630\src\NzbDrone.Core\MediaFiles\UpgradeMediaFileService.cs:line 64
at NzbDrone.Core.MediaFiles.EpisodeImport.ImportApprovedEpisodes.Import(List`1 decisions, Boolean newDownload, DownloadClientItem downloadClientItem) in M:\BuildAgent\work\6c3239faf2b92630\src\NzbDrone.Core\MediaFiles\EpisodeImport\ImportApprovedEpisodes.cs:line 86
16-6-8 19:27:18.9|Warn|ImportApprovedEpisodes|Couldn’t import episode E:\Complete\SabSeries\The.Walking.Dead.S06E15.1080p.WEB-DL.DD5.1.H.264-Cyphanix.1\WrqrBC6uW4H9yb2Z09UVzT4cLggkt1Qk; )=;); )\wicked post.mkv
And some more randomly elsewhere in the log:
16-6-8 19:27:19.1|Warn|ImportApprovedEpisodes|Couldn’t import episode E:\Complete\SabSeries\Zwarte Tulp S01E02 1080p HDTV x264\Zwarte Tulp S01E02 1080p HDTV x264\Zwarte Tulp S01E02 1080p HDTV x264.mkv
