Sonarr version (exact version): Version
3.0.6.1342
OS: Windows 10
Description of issue: I end up with jobs in my Activity/Queue that are 100% complete but just stay there. the log for them say “Not an upgrade for existing episode file(s)” how do i stop it from trying to upgrade episode files.
Thankyou
Debug logs :
Why was this left blank?
need more info; most likely the release didn’t match the file
Thankyou for reply,
I had a look at history of an episode and it said “File was deleted to import an upgrade”
how do i stop sonarr from deleting and importing an upgrade of episodes. Im always happy with the first episode it uploads and dont need an upgrade of anything. If i need an upgrade i can do that manually.
Thankyou
Disable upgrades in your profile / read the docs of applications you use
