How to specify certain torrent uploaders, how to manually add episodes, and why aren't files deleting?
Just started using Sonarr and so far I am loving it. I have a few issues that I am sure are easy to solve but I haven’t been able to figure it out.
  1. Is it possible to specify certain uploaders? I really like the files a certain uploader has of a show. But if it is on auto search it will automatically pick the first one it sees. Is it possible to do this? I saw something under the settings of the show that said “Tags”, but I wasn’t sure if that was it.
  2. I have a few episodes of a TV show already in the folder but Sonarr isn’t picking them up because they aren’t named correctly. How do I make it so it renames the file and then updates Sonarr to show the file actually is available?
  3. After files are picked up by Sonarr, they are then sent to Deluge. It is then downloaded to the drive and then moved to the correct folder. Once it moves it to the correct folder, it leaves the files on the drive. So I essentially have two copies of each download. I made sure I have the delete files checked in the setting page. What else am I missing?
# in Markdown makes it big and bold, just 1. will give you the list you want though.
  1. No, you can only restrict releases by whats in the release title.
  2. Rename them to the standard SxxEyy format and refresh the series.
  3. If the release is still seeding in Deluge it will be copied (or Hard Linked) depending on your Sonarr settings and how the files are organized (hard linking only works on the same drive), once the torrent is stopped in Deluge Sonarr will remove it. You mean the Remove Completed Downloads option, right?
Thanks Markus for the reply.
Regarding
  1. is that something that is a current feature reques? This would be great as some uploaders don’t have the best quality
  2. That worked. Thank you.
  3. The files weren’t being seeded anymore in Deluge and were removed completely from Deluge. Yes instead of “delete checked files” I meant Remove Completed Downloads options, I didn’t have the settings page open.
An additional question, can I specify which indexer gets searched first. i.e. Looks for a file on indexer 1, if it fails then it tries the second or third indexer?
  1. No, we don’t plan to support custom fields from some indexers for filtering.
Remove by what? If Sonarr saw it stopped it would move it instead of copying it and remove it from the client (with that setting enabled). I just wanted to make sure that was the setting, not the Ignore Deleted Episodes one. ((trace logs)) Showing the Queue response from Deluge and the import would be the first step to diagnosing any issue.
No, but its something we will look at down the road: Trello
Thanks Markus for your help on everything. I’ve been using Sonarr now for a few weeks and think it is GREAT! I just wish it supported RAR extraction :smile:
