Hi,
Do you have any tips or dos/don’ts for the next season?
I have a bunch of shows that are cancelled on my list, should I remove them or just let them die in there ?
My main concern is that if the will still be checked for new episodes therefore hitting up my API limit from NZB?
Is there a limit on the database of how many shows I should have? I assume it will be double up when I insert the new shows so I’m worried if the interface will be slow down or something.
Many thanks.
