How to move a series to another directory?
Hello everyone
I just realized that I made a mistake with the directory I point my series to (after searching and selecting one).
I therefore need to move the files to the right directory and was wondering whether it is enough to just move the files and modify the series in question? Specifically, will it recognize that the file(s) are there and not try to re-download them?
I do the same thing,
I got a download folder where i keep all episodes till the season is finished.
When the season is complete i move it manually to another location and edit it sonarr the new location and do a manual refresh/scan.
What also helps is the following setting.
Then you’re sure it won’t be re-downloaded.
