I frequently download entire old series’ that have some 2-part (or more) episodes that have all been merged into a single file/episode. But Sonarr insists on renaming things based on what it expects to be a 2 or 3 parter, etc.
How can I get Sonarr to just ignore these additional multi-part episodes and continue to rename the rest of the season correctly with the files that are present?
Sure, I’m talking about a situation where I have a single 2-hour episode on disk, that I guess originally aired as a 2-part episode, so 2 episodes of 1 hour each. So Sonarr thinks there should be a part (1) and a part (2) but there isn’t. But I’m not actually missing anything, as I have both of them in a single file.
Make sense? It happens quite often on older shows like The Facts of Life, Diff’rent Strokes, All In The Family, Maude, etc. etc. Also on some later shows like Melrose Place.
If you put both episodes in the file name and do a rescan it will update in Sonarr accordingly. Each episode will be marked as completed with the one episode as the file.
Example of something in my library: The.Shannara.Chronicles.S01E01E02.mkv
After renaming it appears like this: The.Shannara.Chronicles.S01E01-02.Chosen.mkv
In Sonarr against both EP1 and EP2 it shows the one file.
