OS: linuxserver Docker image
Hey, I’ve been following the guides to install Sonarr within docker.
I’m not having any issues per se, I just can’t figure out how to do the initial sync / creation of hard-links.
My Docker host has the main folder /mnt/media, with 2 subfolders
- downloads/{shows/movies} # used for Qbittorrent downloads
- sorted /{shows/movies} # Should be used for Sonarr sorted media
Here’s how I mount the directory for the Qbittorrent container:
/mnt/media/downloads/:/mnt/media/downloads/
I just realized while typing, that ^this^ might need to change to /media/downloads
EDIT: Changed it and updated all my fastresume files.
For the Jellyfin container (Obviously this doesn’t work now, since there is nothing in the sorted folder. Before I used to mount directly from the downloads folder):
/mnt/media/sorted/shows:/data/tvshows/
/mnt/media/sorted/movies:/data/movies/
And for the Sonarr container:
/mnt/media:/media/
With all that out the way, I still don’t understand how I’m supposed to configure the Root Media folders, for Sonarr to create hard-links of media from the downloads folder, into the sorted folder?
Could anyone please advise?
