How Do I Fully Uninstall sonarr?
Sonarr version (exact version): 4.9.16.2944 Mac Apple Silicon
Mono version (if Sonarr is not running on Windows): same
OS: Mac Sequoia 15.7.3
Debug logs: none
Description of issue: When I run a utility to uninstall sonarr, the app uninstalls, but when I reinstall, the original configuraiton settings are stil preserved.
Uninstalling won’t remove the “app data” on most platforms. You’ll need to remove the AppData folder listed in System: About to remove the database and all other associated files.
