There are the Indexers I currently use with Sonarr:
6box, NZB Tortuga, NZBGeek, NZBPlanet, Simply NZBs, DrunkenSlug & DOGnzb
I paid a fee for some of the above and just added DOG (trial) this morning.
Since I now use Sonarr & NZBGet exclusively, how do I know which Indexer is responsible for my downloads ? DOGnzb is a little costly and I’m not sure it really adds anything (for me).
There isn’t a way to get a report/overview of what is used, but you can hover over the grabbed items in History to see which indexer it was grabbed from.
Thanks. That worked. It would be nice to add a feature which allows one to see how indexers are performing according to dates or indexer names. I’m guessing if 3 indexers have the same exact files, the one that responds first gets picked, right ?
If Sonarr sees 3 indexers with the same release that it wants to grab it’ll grab one, which indexer isn’t predetermined. It doesn’t matter which indexer was the fast to respond in that case.
