I lost all my data. I had a backup of the Sonarr config and loaded that up. Everything comes up fine except it thinks I have all these episodes downloaded and isn’t auto allowing me to reimport episodes because it already thinks I have it them downloaded.
Can I force Sonarr to do a full disk check for all folders and files and update accordingly?
Thanks I tried to search but came up with nothing. Probably wasn’t using the right keywords.
Yes, but the series folders need to exist (otherwise Sonarr treats them as being disconnected, not missing). You can work around that by telling Sonarr to create Empty Series Folders, which will create the folder, then scan the empty folder.
