Hey,
Doesn’t seem like this series is updating despite being tracked by both IMDB and TVDB.
Is there anything I can do to track this series in Sonarr?
Thanks.
Hey,
Thanks.
Last I read it was removed:
Wow - that’s a pretty serious discussion.
The episodes are still being tracked by IMDB, is there anyway I can use that to update sonarr?
Thanks.
No thats not possible, Sonarr only uses TVDB for episode information and IMDB doesn’t have a proper public API that could be used if we decided to support another metadata source.
Fair enough. Thanks for the quick replies.
Jack I posted here on using Tiny Media Manager
I’ve been able to use Tiny MM to scrape episode info from IMDB for Horace and Pete.
Just FYI, this series has now been added to the TVDB and Sonarr is working fine.
Had to delete and re add the series, so please try that if you’re still having any trouble.
tnx, i’ve instructed skyhook to redirect all old deleted tvdb ids to the new one… all 37 dupes. So anyone with an old one will get redirected automatically when the series refreshes somewhere the next 12h.
Not that it does a whole lot of good, considering it finished airing.
