Sonarr version (exact version): 2.0.0.4859
Mono version (if Sonarr is not running on Windows): 4.8.0
OS: Linux
Debug logs: https://www.dropbox.com/s/irxgmlxu02rdtdz/sonarr%20debug.txt?dl=0
Description of issue: I had 720p HDTV quality of The Expanse season 2 downloaded, and according to my profile that is the most wanted quality with Bluray set as both cut off and lowest (see screenshot) – but for some reason Sonarr just downloaded the bluray release of season 2. I checked logs and don’t see why it would do this if Bluray is lowest priority and set as cutoff? If 720p HDTV is already there, shouldn’t it stop seeking new releases? Thank you
Based on the debug logs Sonarr doesn’t see an existing file for any episode in The Expanse season two as it never compared the release quality to the existing file quality, which would log: Comparing file quality with report. Existing file is {qualty}.
Hmm that’s strange… It was definitely there and the torrent was still active. But the folder was empty so it must have gotten deleted somehow. Oh well, thanks!
