Help setting up Sonarr on FreeNAS
So i’ve been using Sonarr on my PC for a while now, and i love it. But now when there’s an official Sonarr plugin for FreeNAS i’d rather use that.
So what i’ve done so far:
  • Made a backup of my Sonarr database on my PC.
  • Installed Sonarr as a plugin on my FreeNAS.
  • Added storage “links” for all necessary folders.
  • Turned it on to see if it starts, which it does.
What i need help with:
  • Copy the backup from Sonarr (PC) to Sonarr (NAS) so everything is the same. I know how to SSH in to the jail, but that is basically all i know. I have no idea how to restore the backup.
  • Fix any permission issues that might appear. Probably they won’t, but it seems as if i always get problems with my permissions.
I’m running FreeNAS-9.3-STABLE-201412090314 and the plugin for Sonarr is sonarr-2.0.0.2850-amd64
Thanks!
There is a small how-to for synology, but should be very similar. You just need the freenas dirs, which you can probably find on the forum if you can’t figure them out.
Here’s a usefull post.
Thanks for the reply.
I’ve already read that guide, and it didn’t give much.
Sorry if i’m bad at searching, but i can’t find the freenas dirs anywhere.
EDIT: i found the dirs! they’re at /var/db/sonarr
so i restored the backup now. all the settings were copied, but it still says “You must be new around here, You should add some series.” on the front page.
