Help needed to fix my library
hi! need your help here. i have a library with few tv series without subfolder needed to be sorted out with Sonarr but their names are a little bit different from Indexer. How can I use Sonarr to search for those files and auto rearrange them for me? Thank you
Try using a bulk renamer tool to fake a “scene” name. Then dump to a folder and let Sonarr import them manually via the Drone Factory setting. Sonarr will auto move them after you add the shows that you currently have to the appropriate folders.
